Seat citygo Maps en more pid gekracked naar vw.think blue
Geplaatst: di 18 jun 2013, 21:35
door Miisport1
Vanmiddag mijn pid van de seat gekraakt naar vw.
Was makelijk gewoon aansluiten op de pc een map extra aanmaken en in settings 1 instelling veranderen via text editor.
Of wordpad op de windows machine.
Dan opstarten en ke krijgt de keuze.vw up seat of citygo ,polo en nog iets anders.
Dan keuze benzine duesel gas of ?
Dan nog twee vragen en hij start op.
Nu heb ik ook de think blue op de seat erop.
Start alleen op met een vw logo maar dat is simpel terug te zetten.
Re: Seat citygo Maps en more pid gekracked naar vw.think blu
Geplaatst: di 18 jun 2013, 23:22
door Miisport1
OK, so here goes... (this will add THINK BLUE TRAINER from the VW PID unit by letting you tell your Citigo unit, that it is a VW unit - no worry, the design is otherwise close to identical).
1. Connect the PID to your PC.
2. Open the 'Navigon' drive.
3. Create a new text file named branddevice.reg (If your folder doesn't show file extensions (the .xxx after the file name), you will have to uncheck the 'hide extensions for known file types' in 'Folder Options' to see the .xxx file extensions in your folder - in Win7 just click the windows button in the bottom left corner and search for 'folder options' - it will show up - then just click the search result - example below). When extensions are shown, make sure the name is branddevice.reg and not branddevice.reg.txt - this is important. Just rename it if need be (choose yes if it tells you that the file might not be usable when saving).
4. Open the folder 'VwBrandDevice' and then open the folder 'Settings', find the file 'UserSettingsDevMode.default'. Open that file with Notepad and change <active>0</active> to <active>1</active> and save the file.
Now just disconnect the PID - the unit will restart and give you a prompt were you can choose which car you have - choose Volkswagen. 3 questions will follow about your car but they are easy.
Geprobeerd en werkt.
Geplaatst: do 20 jun 2013, 10:27
door IjZeL
Werkt perfect, heb ook meteen alle Seat logo's teruggeplaatst via de andere threads in het forum.
Geplaatst: do 20 jun 2013, 11:32
door henryausepe
Even voor alle duidelijkheid.. Je zegt dat je een nieuwe map heb toegevoegd...alleen in het Engelse stukje zeg je een nieuw textbestand toe te voegen. Beide heb ik geprobeerd helaas werkt het bij mijn Mii niet. Nadat hij opnieuw opstart heb je dan VW Up geslecteerd op Seat Mii ? Hopelijk heb je een antwoord, bij voorbaat dank :)
Geplaatst: do 20 jun 2013, 12:10
door Base
Handig dit!! Thanx!!
Wel vraagje. Mijn PID is opnieuw aan het opstarten en vraagt nu wat voor wagen het is: Kurzheck_Multivan,Stufenheck_Nutz, Variant, fliessheck, Coupe-Sportwagen, Cabrio_roadster_spider, Offroad, Cityvan_pickup, MPV, Sonstige..... nou kan ik er een paar al wel uitsluiten, maar welke moet ik kiezen ????
Geplaatst: do 20 jun 2013, 19:59
door Miisport1
henryausepe schreef:Even voor alle duidelijkheid.. Je zegt dat je een nieuwe map heb toegevoegd...alleen in het Engelse stukje zeg je een nieuw textbestand toe te voegen. Beide heb ik geprobeerd helaas werkt het bij mijn Mii niet. Nadat hij opnieuw opstart heb je dan VW Up geslecteerd op Seat Mii ? Hopelijk heb je een antwoord, bij voorbaat dank :)
Je plaatst gewoon in de map navigon de nieuwe map met de naam zoals boven genoemd. branddevice.reg
Meer niet gewoon een extra mapje aanmaken maar er hoeft niks in te staan.
Dam ga je naar de map settings ,users en dan maak je van de 0 een 1 .
Dan start hij opnieuw op. En kan je kiezen.
Wil je later weer terug naar seat of skoda dan weer het mapje aanmaken.en weer van 0 naar 1 maken.dan krijg je weer het keuze menu.
Geplaatst: do 20 jun 2013, 20:00
door Miisport1
Base schreef:Handig dit!! Thanx!!
Kurzheck multivan.maar maakt niet zo veel uit.
Bij mijn asg werkt shift control niet.andere twee menu's wel.
Geplaatst: vr 21 jun 2013, 07:22
door skogo
Deze goedwerkende mod staat op het Briskoda forum. De instructie is daar wat duidelijker.
http://www.briskoda.net/forums/topic/27 ... itigo-mii/
Verstuurd van mijn GT-P7510 met Tapatalk
Geplaatst: vr 21 jun 2013, 08:38
door henryausepe
Ben er al achter waarom het bij mijn Seat Mii niet werkte. Blijkbaar moet je
als maps&more opstart "VW" kiezen ondanks dat je een Seat hebt, en daarna
zit "Think blue" er inderdaad op.
Wil alleen nog even uitzoeken hoe ik de Seat opstartscherm er weer op krijg ipv
het VW opstartscherm.
Geplaatst: vr 21 jun 2013, 09:22
door Inge
Misschien een niet al te slimme vraag ;) maar wat is hier nu het voordeel van?
Geplaatst: vr 21 jun 2013, 09:44
door Miisport1
Inge schreef:Misschien een niet al te slimme vraag ;) maar wat is hier nu het voordeel van?
Je hebt dat rijd blauw trainer er bij wat je bij seat en skoda er niet op zit.
Dus schakelen indicator benzine verbruik.menu met blauwe balkjes rijden.
Wel geinige optie.alleen met een asg werkt 1 menu niet
Geplaatst: vr 21 jun 2013, 19:02
door Inge
OK, dan weet ik nu wat het doet.
Zie er alleen voor mezelf het voordeel niet zo van in.
Geplaatst: zo 23 jun 2013, 11:36
Inge schreef:OK, dan weet ik nu wat het doet.
Geloof me, je mist er ook niets aan.
Je kijkt een keer in de blue trainer, en je denkt oh nou leuk. En vervolgens gebruik je het nooit meer :lol:
Maar als je het graag wilt kan het dus nu wel.
Geplaatst: zo 23 jun 2013, 12:36
door Miisport1
Op de cruise rijd je bijna alles blauw.kinderspel er is niks aan :mrgreen:
Geplaatst: ma 08 jul 2013, 20:01
door iceman72
hallo, ben ook een super tevreden citigo rijder.
Zou mij mss iemand in normaal Nederland in stappen uit kunnen leggen hoe dat kraken werkt?
Ik heb al heel veel 0tjes omgezet naar 1tjes, maar het werkt niet :oops:
Geplaatst: ma 08 jul 2013, 20:42
Als je de stappen doorloopt moet het niet moeilijk zijn. Het is mij ook gelukt maar die trainer had voor mij geen meerwaarde. Vond het vw logo maar een doorn in mijn oog aangezien het bewegende logo niet kunt veranderen.
Heb niks tegen vw hoor maar staat gewoon niet als je een skoda hebt
Geplaatst: ma 08 jul 2013, 21:02
door iceman72
denk idd dat ik iets niet goed heb gedaan. Het werkt nu net wel Xander. Waarschijnlijk
moet er ook een mogelijkheid zijn om het vw logo te veranderen in het Skoda logo.
Geplaatst: ma 08 jul 2013, 21:41
door iceman72
Beste Miisport1, zou je misschien uitwillen leggen hoe je dat VW logo weer verandert in bv het Skoda logo?
Geplaatst: wo 10 jul 2013, 17:42
door Miisport1
Er staat op het topic van skoda in england precies hoe je dat moet doen.ik stoor me niet aan het vw logo.
Geplaatst: wo 17 jul 2013, 10:19
door IjZeL
Kaartupdate lukt niet meer na dit truucje, ga het maar weer terugdraaien.
Edit: Na terugzetten werkt de kaartupdate weer, alleen is hij nu engels ?!
Edit 2: Na aanpassen configfile is hij nu weer nederlands
